EternalUlysses
Hi, I've been having periodic disconnects from Restream.io while streaming from my Elgato card. I switched from Game Capture to OBS and I like OBS a lot more now that I'm on.
  • 2019-10-31 23-55-26.txt
  • 2019-11-01 13-52-57.txt
  • 2019-11-01 17-19-14.txt
  • 2019-11-01 19-49-31.txt
  • 2019-11-02 11-19-31.txt
  • 2019-11-02 17-55-34.txt
  • 2019-11-03 13-01-51.txt
  • 2019-11-03 16-22-00.txt
  • 2019-11-03 17-47-34.txt
  • 2019-11-03 21-05-59.txt
Exuviax
I've looked through some of the logs you provided, one of the things that keeps jumping out to me is this
 11:58:38 PM.114: [rtmp stream: 'simple_stream'] URL is empty
 11:58:38 PM.114: [rtmp stream: 'simple_stream'] Connection to (null)
What method are you using to stream to Restream? Have you connected your Restream account directly to OBS or are you manually entering the stream key.
Exuviax
In that case, could you try setting it up one of the other two ways to see if that resolves the issue for you? Maybe something isn't setting correctly with the custom setup.
You should be able to find "Restream - RTMP" in the list of options. If you connect your account, you'll also get access to the Restream Widgets such as your Titles, Chat and Channel switches.
