Can anyone help me understand what is happening?(Desperate please)
BigBank
I do not receive any video feed from my capture card. Initially, doing Edit Transform and adjusting the size to 1920x1080 gave me video, but after streaming twice the size's height and width both remain stuck at 90001.00x90001.00. I have tried rebooting my computer, deleting the capture device from the sources, even the entire scene and readding them but nothing has fixed the problem. Can anyone help me understand what is happening or even potentially why? I am at a loss.. If I could provide any other information that may help please let me know, I will be watching this post. I have attached a screenshot of the edit transform window.
Xbox one 2013
Capture card - https://www.gofanco.com/hdmi-usb-capture-device-with-loopout-pro-capturehd4k.html
Mac - MacBook Pro (Retina, 13-inch, Early 2015)
log file - https://obsproject.com/logs/9LE60nC_ggi-vYb0
MORE DETAILED INFO THAT MAY NOT BE RELEVANT
Upon adding the capture device, I do not have the red dimension box, just a singular dot in the corner. When I add the device, the dimensions are set to 0 but anytime I change them and close the window, it defaults to 90001.00. After my initial two streams whereafter this problem has persisted, the problem seemed to "fix itself" while I was sharing my screen with a friend trying to help me troubleshoot my problem through discord. He asked me to remove the USB from my computer, delete the source, replug in the USB, and add it back, and it magically worked although I had performed the same steps countless times before. Again, after streaming twice the problem returned and I have not been able to crack it since. I have done these exact steps but with no results, so I do not think this is helpful information.
