Resource icon
Audio Transition v1.1
dqm
dqm submitted a new resource:
Audio Transition - Mute, Unmute, or Fade Audio during transition
This LUA script that adds source type useful for controlling an audio sources during a scene transition.
Audio Transitions can mute, unmute, fade, ramp, save or set the volume of an audio source when it enters or leaves the program scene:
-Mute and unmute are self-explanatory and instantaneous
-Fade adjusts the volume up or down in gradual steps, unmuting if necessary
-Ramp fades after silencing, first
-Set adjusts the volume without the gradual fade
-Restore returns the...
Pally
Upon downloading, on 3 different PC's, WinRAR, 7zip and Windows 11 File Explorer are saying the zip file is corrupt.
dqm
Upon downloading, on 3 different PC's, WinRAR, 7zip and Windows 11 File Explorer are saying the zip file is corrupt.upp
Not sure what is causing that for some. V1.1 download seems to work better. No changes to speak of.
dqm
There may be an issue with audio-transition "firing" when a transition is initiated from a Stream Deck or websockets. Seems limited to some obs versions and/or an interaction with other plugins. If you experience such an issue, please advise: millerdq@gmail.com
