almost losing 30 FPS??? with 3070tim
RiseBeyond
Hi please help every time i record with OBS i lose a lot of frames way more then normal mostly 20fps sometime 30 fps.
i have a 3070ti laptop with 150TDP
Ryzen 9 6900hx
16 GB ram
SSD gen4
ASUS g15 strix Laptop 2022
using MUX so full GPU power is enabled and in turbo mode
i tested it on a lot of games but they all had same results (cyberpunk used to get 85 OBS give 40-57, Hogwarts legacy used to get 80 OBS give 32-47, control used to get 100 OBS 63-72, ).
I did set my encoder to h264 by NVidia gpu, i updated my obs and removed all my software like msi/Riva tuner, NVidia broadcast.
it gets bad when i open obs but even worse when i record, i have not tried streaming yet.
any help is appreciated thanks
  • 2023-02-19 21-36-41.txt
  • 2023-02-20 17-23-10.txt
RiseBeyond
i would also like to add in these test i did not lock my fps but usually i lock it to 60 and Riva tuner causes big fps drops
JohnPee
The log needs to contain at least 30 seconds of streaming or recording where you have the problem.
