ADVANCED SCENE SWITCHER NIGHTMARE!
On earlier OBS versions this was so easy a 1st grader could do it. Now between Advanced scene switcher and Automatic Scene switcher for the newer OBS 31.1.2 I'm totally lost !!!!!!!!!!!!!!!
I posted two post which I would have deleted if I knew how so please disregard these. As my frustration is mounting here as I was streaming regularly from 2018 to 2022 and now need to return to doing this and with the upgrades and changes to OBS I'm lost with these conditions for changing scenes as it was so simple to set. Can someone please help me out here as I do not know what I'm doing wrong.
AUTOMATIC SCENE SWITCHER
I have scene 1 which has a brower as a source and
scene 2 which haas a camera as a source.
ALL I WANT TO DO IS be able to have the scenes switch after 10 seconds so scene 1 - 10 seconds to scene 2 - 10 seconds then scene 2 BACK to scene 1. Very simple. What has me confused is the dropdown with all various apps so I would think since my scene 1 has a browser in the source so I should select Safari browser in the dropdown which I did, can someone explain to me where I go from here cause I tried every logical step and nothing works.
Lawrence_SoCal
1. glad you figured this out
2. Yes, being aware of plugin changes IN ADVANCE when doing a significant upgrade is important.
There have been numerous comments that the hidden tabs functionality is expected to be deprecated (go away) at some point ... so, glad you found the quick fix. BUT, my understanding is that you are asking for trouble if you don't figure out the new macro/code style approach in AdvSS for accomplishing what used to be done on the Time and Sequence tabs
